Age, Mileage, Turbo & Psi You Have Run
153,000 miles, original internals, original 14b accidently hit 25+ when wastegate reference line came off :p . Usually run 17 PSI
47,903 k miles
T04S 60-1
20psi daily (pump gas) Soon to be boosted more with race gas..
stock motor
..Tranny broke though :cry:
WOW! That's the biggest turbo mentioned yet.That compressor is a 4"inlet isn't it? And the wheel larger than a 60 trim? More tech info please. Mark. Also what injectors does that require?
Xbreed, what fuel is available in Alaska? I've heard that your state has large, good quality illicit substances available so I ws wondering if leaded was commonly available. High test all the way around. Mark
91 Talon AWD
750.1 miles
PT-67 @ 14.7psi (so far)
9500rpm
__________________
I believe he has the biggest turbo so far.
And I run a AGP T3/T04E 50 trim. .63 a/r
Built motor....10 psi and pulls hard as hell
Going back to the dyno in a week or so so the final full throttle tuning with as much boost as it can hold! Pump gas 92 octane so ill shoot for 22-26 psi tuning with the AEM
Hey Omaha, I sent you an email as we have the same turbo's, the AGP RS49. We both have a'93 model year also. Do you run an internal or externa gate? Did you have to change one or both fans for turbo fitment? What size inj's do you run? Anyone ele here have a similar turbo that culd help wth these ???.? Mark
Bigger than the 60 trim
4in inlet
I use 850 fic injectors.
I have also ordered this turbo from AGP..ITs a full garret setup.
Bit laggy wont start seeing boost till about 3500 then once it hits 4000 it just hauls
I have an auto tranny so once it hits that 4k the wheels chirp like crazy
92 laser rs awd
180,000
stock with 3" back and evo3 16g
14psi and even at 10psi (wastegate spring) i hit fuel cut
but it runs like a champ.
ramchargers MAFT and GM 3" comeing soon along with a front mount :laser:
T25, max boost.. 22psi
11,000 miles on the engine and turbo
The fuel in Alaska used to be 92 octane, but is now 91. Race gas is 104 unleaded or 110 leaded. $7.50+ a gallon since a month ago.
Man a strong automatic with a shift kit would jump 20 feet when it shifted at 16 psi! As far as boost cut the MAF will eliminate that. i will be installing my 50 trim this weekend. Will keep youall posted. mark
