Aftermarket Evo cam gears in a DSM??
Ruben16V
44
May 22, 2008
Madrid, Spain, Europe
Well, I've been reading and can't find a firm answer.
I got a very good deal in a set of hks cam gears, but they came out of an Evo VIII.
I' ve been searching and it seem like the timming marks are different, so I'm wondering if I put the HKS gear over the stock one alignin the cam pin hole and I make new timming marks with a dremel, Could I use the Evo gears without any problems???
Perhaps is an idiot question but I don't want to spend a lot of money on cam gears and I think thats a good chance
No, our motors spin in the opposite direction and the timing sensor in the Evo 8 is on the exhaust cam.
The engines don't spin opposite directions, they are just mounted opposite. And the CAS has nothing to do with cam gear selection since it's driven by the opposite end of the cam. The only exceptions are the 95/96 DSM which uses a trigger plate mounted to the intake cam gear itself and the Evo 9 which has MIVEC.
HKS cam gears are simply labeled "4g63" since they are interchangeable between DSM/Evo. They have 2 sets of timing marks so they can be used on either engine. Take a look for yourself. You can see the Evo timing mark which is straight up from the Dowel pin, and the DSM mark which is 90* from the Evo mark.
http://www.streettunedmotorsports.com/parts/hks_purple_cam_gears.htm
They do have seperate locating pims on evos to our dsm's, it can be drilled to fit our engine but might not have the marks for timing though. Other then that all cam gears from.a 4g63 are pretty much interchangeable
Ok, thank you very much.
So as I thought they are all interchangeable, and if not, you only have to make new timming marks.
I'm going to buy and try these set of HKS gears :thumb:
