aftermarket clutch installation. need answer fast!!!
Stainbox12
378
7
Jan 3, 2006
Panama, Central America
ive got a centerforce street disk, but i removed the tranny a while ago, along with the disk and the pressure plate. the disk, has some pucks in on side, and the other side is completly flat, but i dont remember something. does the pucks face the flywheel or they face the pressure plate. i need to know because im working on it right now. thanks :thumb:
Ok I think I got what your saying but not sure the clutch disk if you hold it to the flywheel one way and the outer part dosnt contact it then flip it around and then the outer part sould rest on the fly wheel install the alignment tool and then put the pressure plate on.
If this isnt the info you needed try to explian a little better or post pic.
Brandon
It will only be able to sit one way if you flip it around the springs will hit the fly wheel if you set it on there the friction pads should contact the flywheel put it on both ways you will see what I am talking about. The out side of the disk will not contact the fly wheel if it is on backwards.
Brandon
Did you get it o am Ijust being retarded and not understanding what is going on. Tell us what is up.
Brandon
yup the sprung side of the disc goes toward the tranny and the flat side toward the flywheel
