tstkl
- 3,890
- 78
- Feb 10, 2005
SoCal,
California
dude, if your not willing to tune your car so that your idc's are below 100%, fine, but DON'T ask us why you can't run 16.5 psi because everyone says THEORETICALLY you can run that. You probably have a boost leak or something, but either way, DON'T run your car hard when the idc's go above 100%selmerguy said:It regesters just fine..... I just dont understand that everything I have read and been told is that 16.5 psi is all you can run SAFLEY on a stock fuel system.. 136 IDC is not safley.
and the knock at lower rpms is most likely phantom knock. It is caused by the lifters ticking or something else like that, it doesn't really matter that your getting phantom knock as that won't effect your higher rpm knock whatsoever. If your getting knock in higher rpms, YOUR TUNE IS OFF, or something is wrong with your car, AND YOU SHOULD CHANGE IT UNTIL IT STOPS KNOCKING.
KNOCK IS BAD, IDC'S OVER 100% ARE BAD, DO YOU UNDERSTAND ENGLISH?
I think that day at the dyno was particularly bad, cause I wasn't seeing even close to the airflow I was seeing on better days.
