AFPR how hard to istall and what fuel pressure to run?
GstRacer
409
3
May 6, 2003
BooneDocks, Connecticut
ok jst bought the areomotive AFPR and the ss fuel line install kit for the regulator and the fuel rail to filter how hard to install and what fuel pressuer should i be running i aloso have a 255 fuel pump rewired and a AFC-2 tuned to what i have now at 15 psi thanks for the help :thumb:
install is pretty much remove then replace...nothing too fancy with it
no real tips i can give ya cuz its not a very difficult task other then to check for leaks, use teflon tape where needed, and make sure you have the FPR mounted in a secure spot
no real tips i can give ya cuz its not a very difficult task other then to check for leaks, use teflon tape where needed, and make sure you have the FPR mounted in a secure spot[/QUOTE]
Ah, I don't think you are supposed to use teflon tape on -AN fittings.
If you pull your fuel rail....make sure you get new injector O-rings and insulators...I've found that everytime I ran the car for a while and then had to pull the injectors and put them back in, that I always ended up with leaks since they became hard as a rock.
Mike
