AFPR at fuelinjectorclinic.com?
As far as I can tell you are talking about a the fittings they sell for use with an Aeromotive FPR. Read it again...it does not actually include an FPR jus the fittings and a gauge so that you can bolt one up* to your car.
*I have an Aeromotive FPR with a CHM gauge and those same fittings as sold by Slowboyracing. It still requires a little fabrication to make work, namely cutting part of the upper timing belt cover, and some work to the mounting bracket if you want to bolt it to the firewall.
I personally feel it is a great set up for a 2nd gen, but the Buschur SX unit is nice if you have a 1st gen fuel rail like you do.
-T
edit, the fabrication I had to do is for my 2nd gen Manual. It may not be necessary for a 1st gen or for an Automatic vehicle.
