aeromotive fpr installed and now car wont go past 2k
tmoney5500
Apr 27, 2005
schwenksville, Pennsylvania
I need help! I just installed the aeromotive fpr and set it at 37 while idling and the gauge reads 43 with the vaccum hose disconnected. The car idles low and will speed up the fuel pump and raise the idle to almost 1k. When the car is put in gear, it will almost stall. The car will not go over 2k without stalling and actually shut off when driven up the street. I lost all power to the engine and had to drift back home wiith no power steering. The car would even crank. then when tried later, it starts but idles like garbage. I need help. I have no idea what is wrong with it.
yes, I used the same vac line that was connected to the OEM fpr. My vac line however is split between the ebc and the fpr put comes into one before it reches the sensor. Then only thing that i can up with is that the line running to the intake manifold is streched to the limit and may be cinked. I shall try and move the line around and see if it gets better, but there are no leaks in the system and it my car worked fine before I replaced the OEM unit.
well I fiddled with the vaccum line on the intake manifold and now evrything works fine. i have no idea what I did but what ever I did, I am glad I did it. Thanks to all who took instrest in this problem of mine.
