Aeromotive AFPR
DSMcrazy3
N/T DSM Wiseman
DSM Wiseman
2,196
62
Dec 29, 2004
Humble, Texas
Alright well I'm planning on building sort of soon here...Currently I have 12:1 FMU on stock injectors.
My friend is going to turbo soon, so I was going to go ahead and get the aeromotive 1:1 AFPR. My question is, is there anything else I will have to get at the same time for it to work before my rebuild? Can I just run the AFPR on the stock injectors and walbro 255 like I have the FMU right now?
Also will I have to get SS fuel lines with that since the nipples are threaded? If so, do I need to get a threaded fitting attatched to the fuel rail?
Keep in mind I'm a 95 so my fuel system is slightly different than newer years.
Thanks
...is that aeromotive 1:1 gonna give you enough fuel pressure during boost ;)
Quite true. You may wanna consider larger injectors or Corbin's 8 injector set up.
You can always get thread-to-barb adapters if you don't want to get SS lines.
This is taken from Corbin's site, but you can see how he used an adapter to use plain rubber hosing.
attachment.php
