ECMlink AEM wideband with DSMLlink
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
I have an aem wideband i been trying to get everthing hooked up to start tuning. I seached up but cant figure it out. My problem is that the guage reads acurately on the guage but on link it reads like 10.1 and on the guage 14.9 at idle. When im cruzing and floored it saty betwen 10 and 11 ratio. I used link and set it on the rear input but it read very unacurate? The wideband o2 sensor is hooked up to the rear 02 sensor spot and i have no cat and i used the pin for the rear 02 spot but i just spliced it in and did not cut the wire coming from the ecu. The wideband is on po4 mode not sure if this is correct?
Did you set up linear wideband? The aems are finicky. I know on mine I had to set up linear wideband and adjust the switch points. YouTube linear wideband setup
