ECMlink AEM wideband simulating narrowband
KGB Pilot125
486
Oct 20, 2002
Centennial, Colorado
Anyone doing it?
I have mine simulating narrowband to DSMlink and I swear I can feel it going rich and lean. I know its only swinging 1-1.5 points but it feels like someone is giving me 3-5 psi of boost even though everything is constant. This mostly happens on the freeway cruising with the cruise control on.
Think it would be smart to add another bung and run the stock 02 sensor also?
Where is yor sensor mounted? When they are to far from the stock location this can happen. If you mount it in the stock location, this doesn't happen.
Its the only 02 I am running so its in the stock location.
AEM suggests mounting the sensor 18" downstream of the turbo. I would move the wideband O2 to the downpipe and install the factory O2 in its proper location.
Those wieband sensors don't like getting too hot either. So having it on the o2 housing would be a bad idea.
