aem wideband question
gnes100 said:
http://www.aempower.com/product_ems.asp
Whats the difference btwn the gauge type aem uego controller and the wideband uego controller ?
The gauge type has a gauge and doesn't have an output to send to the stock ECU. Because it has a gauge you don't need a laptop to monitor your A/F ratio. It does include a "Serial data stream included for output of AFR (RS 232)", so the AFR can be logged with a laptop.
The "AEM Wideband UEGO Controller" doesn't have a gauge, so the data can only be read using a laptop. It does have an output to send to the stock ECU. It also has a wideband output so you can add the "UEGO Display Gauge" if you want to monitor your AFR all the time, and not just with the laptop.
