1G AEM wideband install
Boost Freak 3
101
May 20, 2006
Schaumburg, Illinois
I need to extend the 4 pin wires on the uego so I can reach the ecu anyone know what kind of guage the wirring is? Also the 5v white wire which wire does it go to on the ecu I have heard many different things. I have a 1g ecu if anyone would let me know which wire to hook into so I can log a/f with dsmlink that would be great. Aslo then were does the blue wire go?
If the white wire is the 0-5 analog output from the kit, you basically wire that into whichever ECU input you want to use for datalogging. We have a page on our wiki with a few details:
Available ECU inputs
We also have several other pages on our wiki that can help with this, including the following.
General aftermarket sensor installation
Basic example using a Zeitronix on a 1G
Thomas Dorris
ECMTuning, Inc.
I did search but everything came up with different answers and I wasnt positive. Thanks for the help I was lookind through the wiki but I must have passed that up! Thanks it makes more sense now
Yeah, the problem here is that it's hard to document aftermarket sensor installation because there are so many different kits (some of which have multiple versions!) and so many different ECU inputs to use with so many different special considerations, it's just hard to lay it all out in a nice, clean diagram.
Thomas Dorris
