GVR-4 AEM EMS V1 1G PNP IDLE ISC VALVE CIRCUIT ISSUE
Elpizer2
167
21
Jul 31, 2022
Miami, Florida
Hey guys, ok this is my problem.
I've been having issues with my AEM ems v1 since the begining I bought it used and you know.
I already check all wiring harness, everything is good. The Idle control from the AEM ems v1 sometimes works and sometimes not.
I decided to open the ECU ems v1, I found this
It has 2 stepper control L9935 - Two-phase stepper motor driver
Pins 58/59 67/68 from ISC Idle valve does have continuity.
Down there is a Mosfet transistor 1nv04
Ok, so I decided to remove the transistor 1nv04 and the 2 stepper drivers L9935.
The transistor 1nv04 is bad, I tested it using a tester but here is the thing.
I have ground between the 2 pins on the transistor 1nv04 on the board, they does to ground. that's is weird, does anyone can help me please?
I mean, I can get these components from amazon or ebay but the thing is that is there a short to ground in the board the new components are going to burn again
