AEM EMS---> Laptop What cable?
4g63telantra
454
Dec 10, 2004
Toronto,
Ill be picking up my EMS soon, just wanted to know what cable i would need to run in to the laptop?
Laptop uses a UBS port
Do i just get a USB cable from EMS to laptop?
I now with DSMLINK I had to get a cable from dsmlink site.
You will need to get a USB to serial port adapter. The best one to use is the Keyspan adapter. You can get them from Comp USA for about $45.
This is the only one the seems to always work. I have used a couple different adapter cables, and the Keyspan has been the only one that works with all of the software I used.
Thats what I was going to say, I cant believe I forgot to tell you to get an adapter. I though that maybe now the newer AEM would have a USB port. I was in a new Corvette and it has a USB interface for the diagnostic port. CRAZY
I've had problems with the USB to serial converters. AEM recommends that you get an expansion card with a 9 pin serial port to elminate the chance of problems. It's not uncommon to completely erase the chip in the ecu when you're installing or upgrading the firmware and using a converter cable.
Next time you want to ask a bunch of questions about something try to put it one thread, it saves time and space.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
