AEM EMS and Cyclone intake question
ceedawg
Supporting Member
1,527
216
Nov 9, 2002
laurelton, New York
Has anyone setup a cyclone intake manifold with an AEM EMS standalone?
I am looking at how to set the butterflies up to work electronically.
Depending if you need a positive or a negative trigger to activate the butterflies, you can use either a High Side or a Low Side output. Just connect the desired output from the pin out on the ems to the butterflies and go to Options > Configure Outputs and set your parameters for when you want them to come on based on rpm, load.. etc. Should be pretty straight forward.
Thanks so much I appreciate this info.:thumb:
Turboglenn is using a haltech ecu standalone to control his cyclone. You could ask him about his setup.
Thank you!
Did you evr get this taken care of? if you need i can either guide you through setting it up, or i could just take a copy of your .cal file (map) and make the needed changes for you based upon the desired pin youd like to use to trigger it. you will basically be usimg a solenoid from either a 2G DSM fuel pressure solenoid, or any similar 3 port solenoid. you will also need a GOOD one_way check valve that can withstand the lvel of boost you plan to run.
ive been messing with the open and closing poinys based onoad and RPM. if theres anyway i cam help you out just shooy me a PM.
Sure thing thanks.
Mani should be here next week I'm hoping.:thumb:
I also will be using the fpr solenoid. Gonna get the check valve from Dodge.
cool, hit me up if you need any help in the line of programing or a diagram of setting up the actuator (using the OEM cyclone stuff) with the FPS and a check valve, I can get you pics as well as a diagrfam of mine showing flow under vacum (and boost if you need it added on)
For a daily driven car in the ~500WHP range i think this is the best manifodl a guy can have to be honest... Sure it gave up a few poniues up in the very top end but i have so much of a wider power band now that i rarely need to downshift for anything other than to rocket off from some one to show em the mitsu is mean as hell LOL
