AEM Cam Gears??
04bls84
69
Apr 13, 2010
Lewistown, Pennsylvania
Ok here is the info, I am running a set of AEM Tru-Time Cam gears I got from a friend that I traded rims to on my 97 Talon TSI. My Question is what is the best setting for them? I had to set them both to 5* advanced for everything to be set at TDC. Is this bad or good? The car runs fine except for using a lot of gas. Is this because of the timing issue? Please Help!!!:banghead:
You need to degree the cams in with a degree wheel on the crank to get true 0 and then adjust.
0 isn't always the true "0". You need to degree them to properly set them up.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
