cam gears
TSi90
Dec 6, 2002
hey whats up everyone i was thinking about putting some aem cam gears on my 90 model talon tsi awd and i was just wonder if it was really worth it because i can't figure out what kind of a diffrence adjustable cam gears would make make besides making it really easy to bend valves, well if anyone knows what kind of diffrence cam gears make it would help me alot.:talon: :talon: :thumb:
the Dyno is the best way to tune them. Other that that there useless by seat of paints.
it's look cool under the hood but hard to tune.
Originally posted by TSi90
what do you mean they are useless to me?????????
Adjustable cam gears allow you to adjust valve timing, which is a rather high level of tuning. Until you get to that point, there are many more tuning points you have to go through, and only after you reach limitations of ignition timing and fuel tuning, should you go for adjustable gears.
he is saying that right now at your stage of upgrades you have, adjustable camgears are far from being needed. most people get them when they upgrade cams. you should go over the tuning guide on this site. they spent alot of time on it, for a good reason.
the only reason i can think of to get them right now would be to make your engine bay look flashy.
if you plan on some headwork (porting, valves, camshafts, etc) and getting into some hardcore tuning, then go for it. otherwise, it's not worth the timing belt removal to install them
hey thanks alot. i guess instead of gears i'm prob going to save up a lil extra money and get some new cams after i get my head tricked out. i didn't think putting cam gears on an almost stock car would be worth it. by the way what size cams should i get if i want to still be able to drive my car on the street but i want to be able to notice a diff in power.
Thanks for the info, I was kind of curious myself. But even in reading, I wouldnt advise any of this without some data logging equipment.
Originally posted by StockSpyder
I dont know what cars you guys are speaking of, but in a 4g63 cam gears are a great bolt on. Allows you to play with overlap. Check here if you want some more info..
Cam Gear Info
Hope that helps :)
Shut up John, you don't know what you're talking about :D
Cam gears are evil ! Muahhaaa hahaaa.....
Depends, HKS cams are all i would spend my money on.
This is where you need to really sit down and ask yourself "What do i want out of my car." I know you are thinking that you want an all out race car, but be serious.
There has been a huge review on HKS cams with different types of turbos. With a big16g or smaller, go with a 264/264 (intake/exhaust) combo for the low end spool. With a 18g to green, get the 264/272 combo, and anything bigger than that, go 272/272.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
