advice on newly bought 95 eclipse GS
darkdragon8036
Aug 25, 2009
Hagerstown, Maryland
I bought a 95 eclipse GS that was already modded out, so my question is, was it worth paying 3800$ for with the mods listed below? The only problem I had was the engine fuse blowing when I shifted from 1st to 2nd. So any info on what would be the main cause of it blowing would be awesome :). Thanks for any advice.
Engine Modifications:
-Bored .020 over
-JE 8.8:1 pistons
-JE rings
-Full floating wrist pins
-Eagle H beam rods
-Clevite 77 main/ rod bearings
-Polished crankshaft
-Balanced rotating assembly
-Re-surfaced valves
-ARP head studs/ rod bolts
-Felpro MLS headgasket
-Melling high volume oil pump
-AF/X30% underdrive pulley
-Fidanza adjustable cam gears
Turbo Modifications:
-HRC Turbo manifold
-HRC Super 20g turbo
-Turbo XS manual boost controller
-HKS SSQV BOV
Transmission Modifications:
-Southbend stage 5 modular clutch (<5000 miles)
-Lightweight flywheel (<5000 miles)
Fuel System Modifications:
-PTE 780cc low-impedance injectors
-Megasquirt 'n' Spark V2.2 ECU
-MNnS-extra code 029t
-Accel in-line fuel pump
-Aeroquip fuel fittings
Exhaust Modifications:
-HRC 3" downpipe
-Maxflow 3" cat
-Thermal R&D 3" cat-back
Suspension Modifications:
-Tein Basic Dampers
-SPC adjustable front upper ball joints
-Infalls rear camber kit
Electronics Modifications:
-Zeitronix ZT-2 Wideband, A/F, Boost, RPM, EGT, Lambda
-Viper 5000 alarm
Blowing the fuse, means you have a short somewhere.
$3800 is a lot of money to spend for a 420a.
are all the receipts with the car? and can he prove that everything listed was done?
also we need some pics.
and what is he using to tune it.
Yeah I have the receipts and all that. I bought it from Grease Monkey here in Hagerstown. I talked to the guy who owns the shop and he explained what all was done along with the proof. I can't upload any pictures yet because the internet I use isn't fast enough, in time I can though. It's no doubt the cars fast and seems to be built right, but without a 4g63 motor in it, I gotta get as much info as possible. To me building a 420a is worth it but to others I just keep getting the ol' "buy one that's already turboed". I have a 90 talon tsi in west virginia so I need something different.
  • Wanted 6 bolt NT water pipe
    • chrisman287
