Adjustable Hi/Lo boost problems
ttsrq
75
Sep 8, 2006
Kelowna,
Ok so I was looking through the dsm tuners forums and found this mod and thought it would be cool to try it. http://www.dsmtuners.com/forums/showthread.php?t=196100 and http://www.dsmtuners.com/forums/showthread.php?t=220530 so I did what it said and its not working. For the wiring I took a wire from the ACC on my switch and wired it to one of the male connectors from the BCS.. then I wired the positive on my switch to the red wire in my stereo wiring harness...then wired a ground to the other BCS male connector. Then I wired the ground from my switch to the ground in my stereo wiring harness. After I did this all nothing worked..the switch did not work aswell as my stereo..I checked the fuse and it was blown I then replaced the fuse and it still wont work and the fuse is fine.
I then took the car for a test drive to see if maybe the switch light was burnt out and I boosted to 25 psi EEEEEK.... So heres how I rigged up the BCS and the MBC.... The MBC is connected to the waste gate and the nipple coming off of the turbo...I then put a T in the line between the turbo nipple and the MBC and connected it to the flared side of the BCS I then put another tee in the line between the waste gate and the MBC and hooked it up to the other side of the BCS. Any help would be GREATLY appreciated.
