Adjustable fuel pressure regulator worth the money?
VIPERBLUELX
Dec 3, 2004
Ringgold, Georgia
If I'm running stock injectors, is it worth the money to get an adjustable fuel pressure regulator and bump the fuel pressure up till I get get bigger injectors? I'm running around 17-18psi with stock injectors, upper pipe, hks tb elbow, full 2.5" exhaust.
The injectors can only flow so much. With or without raising the fuel pressure you could be potentially maxing out the injectors anyway. Just get bigger injectors.... Or turn the boost down a notch. :dsm:
It can be used in the manner you are asking but you have to keep in mind there is only so much the stock pump can flow as well.
I think the money would be used wiser on a pump, or towards a larger set of injectors and a Safc.
