UCSLugRacerX
- 166
- 0
- Jun 9, 2004
Santa Cruz,
California
One of my primary reasons for gravitating towards the 1G DSM, is the 50/50 power split from the center differential. However, there seems to be more built-in understeer than desired. To try combat the understeer characteristics, most people here raise spring rates, add stiff shocks, replace rear anti-roll bars with a thick/stiff ones, add stiff rear strut tower bars, and try to stuff as much tire as possible under the fenders at all costsadding offset wheel spacers and rolling fenders. Although, most of this perhaps would lead to instable oversteer, (if they havent already added too much front negative camber, or front toe-out) and perhaps adding to unpredictable power-on oversteer. (Especially with the guys spooling up huge 20Gs, on a 2.4ltr.) Also, considering the turbo lag on big turbos, wouldnt the non-linear HP curve upset steady state turning while accelerating and turning, and perhaps induce unpredictable and instable power-on oversteer? Also, wouldnt this decrease the predictable transition period between steady-state turning tand oversteer?
My question which Ive raised before, was that given the inherent tendency to understeer, and the power split, what can we do to increase the capacity for steady state turning? (Meaning, the car will not be understeering, nor oversteering an abhorrent amount, until tire traction limits are reached, or by extreme tire slip angles.) Also, could we do this without stuffing 275mm wide Hoosiers under the fenders? (Nonetheless hats off to Greg Coiller.)
From reading several threads, DSM members here modify their suspension systems in a follow the leader fashion, without really looking at what happens overall to the cars handling characteristics. Also taking into account the large amount of power some your 4G63t motors are putting down, having more HP will actually AMPLIFY suspension problems. (Thus I think this is a problem to be dealt with.)
What makes a 3,000 lbs car with a power split of 50/50 heavily understeer? Is it the overworked two front tires (both steering and accelerating or braking), which cause it to arrive at its limit all too soon--leaving the traction circle? Is it the somewhat long wheelbase, which delays the chassis turning response time? Does anyone have data on a 35/65 Cusco center diff on a 1G? (Or data on the cusco diff on a car with a better f/r weight distribution that is closer to 50/50?)
I understand that this subject was covered in the frequently asked questions, and DG-FNR exclaimed: First, we have to all understand one basic fact about DSMs - they understeer under power. NOTHING you can EVER do is EVER going to fix that.
Well, that is a bunch of BS and dramatically pessimistic. A 1G AWD will understeer AND oversteer, as it heavily depends on the conditions, whether its low speed, high speed turning, the steer angle, tire slip angles, power distribution, toe, camber, weight transfer and MANY other factors.
If this sounds over the top/crazy technicalits really not. And I dont mean to sound like an arrogant prick, if I ever have in my posts. Ive just got questions that hasnt seemed to be answered.
I am planning on buying a Quaife up front. That'll help me pull out of the occasional slide.
