Red 4G63
- 137
- 6
- Jan 29, 2006
Rochester,
New York
I'm in need of some help with the Infinity Amp + Aftermarket HU (Kenwood DDx512) + Second Amp and Sub. I've read almost all of the older posts about these issues, but mine is a bit more specific and no one really answered this question. So, I'm hoping to get a straight answer.
Background:
I've already installed the Kenwood HU and the MITAH adapter, all new Pioneer 3-way and 4-way speakers and that's all working correctly. But I noticed on my HU that I only have 2 sets of RCA pre-outs, which are being used by the factory amp (via MITAH 6 PIN cable to 4 RCA) but I wanted to hook up my second amp somehow. I tried using a Y-splitter for RCA's off either channel, but that won't work for some reason and I know it can create horrible feedback, so I'll pass on that. I wanted to keep the tweeters without having to install the X-overs and such, so I was just going to keep the Infinity amp for now... but I would like to have the Sub working.
Question:
Is it possible to just get a Line Converter for the rear 6x9's to have another RCA output for the rear Amp? Everything is hooked up and powered, including the in-line tap for the Remote wire off the MITAH. The amp turns on and off as it should, just no RCA connectivity from the HU. Without re-wiring and buying a ton more things (X-overs, replacement Amp for Infinity amp), will the Line Converter work for me?
Thanks in advance.
Jerrod
I believe I found the answer in the VFAQ section in a write-up, I just wanted to get some feedback from others on here that have also done this and any suggestions or advice they have with their experiences.
Thanks.
Background:
Question:
Thanks in advance.
Jerrod
Thanks.
