Please Support Kiggly Racing
Please Support Rix Racing
Street Build Red 4G63's Eclipse GST Spyder
Ownership Status
Currently Own
Mitsubishi Eclipse Spyder GST
Turbo Type
16g
Drivetrain
FWD
Build Type
  1. Street
Split Thrust 99block, Evo3 Crank, Eagle H-Beam Rods and Arias 8.8:1 pistons. ECMLink V3 + EPROM ECU + LC-1 Wideband with Gauge. Thermal Coated FP Manifold. Thermal Coated MHI EVO III 16G + SS o2 housing. Hallman Pro Rx MBC (set to 18-20psi). PR FMIC. Running full SD + Greddy Type S BOV. Bosche 2200cc injectors (new seals and filters). Re-wired Walb 255lph. NGK Wires + BPR7ES. Stainless DP w/o cat + Thermal R&D + EGR Blockoff.
Mods-Engine
7bolt Split Thrust Block, Evo Nitride crank, Eagle Rods, Arias 8.8:1 pistons, MLS HG, HKS 272/272 cams, BC Beehive springs Titananium retainers, 3G lifters and AEM Adj Cam Gears
Mods-EMS & Logging
ECMLink V3 w/EPROM ECU. Innovate LC-1 Wideband with AF/R gauge. AutoMeter Lunar Boost and Voltmeter Gauges.
Mods-Drivetrain
Prothane all motor mounts. Act2100 Clutch + Pressure Plate + Act Streelight Flywheel. Not Installed: SBR LSD.
Yonaka Adjustable Coilovers, Prothane Upper Control Arm bushings. Front Strut Tower Bar.
Background
Florida car, no rust. 350-400hp is my goal.
1/8 Mile E/T
6.0
1/8 Mile MPH
60
232 lb/ft
Red 4G63
More in 2G DSM
Share this Vehicle
