add 50hp to stock
civickiller
119
Nov 6, 2004
Salem, Oregon
I have a 95 tsi fwd stock with 400venom chip. i would like to add 50hp to my car. can i doit by replacing my bov with 1g and add electronic boost controller? Is is like 13psi?
A 1g bov will give you no horsepower. It will not break or leak when you raise boost, unlike the 2g. Take a look at this, http://www.dsmtuners.com/tuning-guide/2gturbo/. Should help you find some answers. If you have questions about it, do a search before posting, chances are it was probably talked about before.
Not exactly sure because I havent had it dyn'd but from what I've raced & from my reading I would imagine I have around 50hp or so more then stock with the stock t25 turbo, which is maxed out & will be replaced once I get the car out of winter storage :thumb:
So this would be what your lookin at
Injen intake
upper & lower ic pipes
1g bov
boost controller set at 16 psi
ported turbo
ported O2 housing
3" downpipe
3" high flow cat
apexi N1 catback exhaust
boost gauge (of course)
