Act 2900 with six puck "sprung" disk
PSI NRG
328
5
Nov 2, 2004
Solon, Ohio
I've been lookin around for a 2900 with a 6 puck sprung hub disk and I havent come arcoss anything yet, does anyone know if it exsists? I need a clutch that will support over 500 torque or more. I've seen the HSK tripple plate...kinda expensive but if it helps with driveablity might be worth it. Also I've only seen they sell it for a 7-bolt motor not the 6. Driveablity and holding power are the biggest factors. Mostly will be dialy driven maybe to the track a hand full of times.
If anyone has some suggestions as to clutches that will hold the kind of power I will be making please let me know thanks!
The guys at Slowboy recommended to me the 2900 with their sprung 6 puck. I was going to go with the hpf bronze disk, but they said that competition makes both disks. The only problem with this combo is that on the track slipping the clutch alot will heat it up and make it grabby and thus hard on the tranny. When cold the clutch should be very slippable which is really important for streetability with a six puck, and should easily hold the power your making.
