act 2600 clutch release problem
super97gst
376
10
Nov 18, 2004
Clinton, Kentucky
i just got my new act 2600 clutch and act streetlite flywheel installed a couple days ago. i was used to my stock clutch not engaging until the pedal came off the floor 2 or 3 inches. this new clutch releases the instance the clutch pedal comes off the floor. is this normal?? or is there some type of adjustment on the clutch linkage that i can adjust?? thanks for the help guys.
Instructions should have been in the box and it includes basic instructions on adjustment. You can also download them from our site at www.advancedclutch.com. Also look at the tech bulletins for more tips.
I had the same problem with my 2600. I shimmed a new pivot ball with one washer, and adjusted the master cylinder rod a bit, works fine now, oh and I also used a new factory fork.
