Acceptable amount of kink in oil return line?
x5150
63
Nov 10, 2008
Irvine, California
Is this an acceptable amount of kink? It was a miracle that I finally got this thing to even bolt up.
If the car does not smoke then I would say it is OK. In the pics it appears to be kinked a decent amount. It really does not take much of and obstruction in the return line to cause the turbo to smoke. But like I said if it doesn't smoke then it's fine.
Why not just get a 90 deg.elbow fitting on the oil pan instead of that 45? It will work that way but it looks a little hoakey -
this is the extremepsi kit, came with at 45 degree. This is my 2nd kit too, tried the ebay SS one but couldn't get it to fit.
I would say the 90* would be to much, It looks fine as is but if it worries you get a 60*
Just fired it up. Let it run for a few minutes, turned it off then the fitting started to leak.
I'm going to ask them for a 60 degree fitting and more hose. Ugh, car is going to be down for another week I guess.
extremepsi was nice enough to send me the 90 degree fitting and new hose, but the 90 degree fitting leaked exactly like the 45. I got an oem one installed in 10 min, no leaks, works perfect. Man wasted 2 weeks waiting for parts, hours of labor, and $110.
