AC relay delete
KFred 513
146
Oct 11, 2012
SUllivan, New York
I have both harnesses out of my car to eliminate the unnecessary and tuck the rest. AC is gone so i want to get rid of the wiring in the fuse box harness. If I delete the AC condenser fan, and dual pressure switch relays, I will not interfere with the blower motor will I? I am keeping heat, so I need the blower motor still.
So did you end up deleting the a/c relays in the fuse box?
I wanna delete all a/c and abs relays and fuses in the fuse box as well for wire tuck. Just don't want some other random nonsense to happen.
When doing this you need a dsm electrical manual for you car all my a/c is deleted so everything for a/c is gone even a/c fan. I just took my time making sure i did everything right.
