AC Line
crimsondragon
4,300
51
Dec 17, 2006
East Brunswick, New Jersey
What is that steel tube that runs along the firewall for? There's a twist cap on it that has the letter H on it. I need to know if this line gets hot or anything like that. If it does I'll need to relocate my pressure sensor.
It's the output line of the compressor. It's how air conditioning works: the compressor crushes the refrigerant down to a hot gas, it's run through the condenser to cool and liquefy it, and it's allowed to expand and suck up heat in the evaporator, then back to the compressor. The high pressure side should be just about hot enough to burn you. If not, you may be low on refrigerant.
http://autoacrepairs.com/actheory.html
http://autoacrepairs.com/EVSFlow.html
