2G AC compressor removal
dsm144
112
Jun 7, 2011
Conover, North Carolina
Most of the threads Ive searched are with the motor already out. If I didnt want to take the motor out would there be a way to remove the AC compressor? I know its going to be a pain in the freaking butt but I really dont want to have to take out the motor if its not needed.
You can get it from under the car. If anything disconnect some motor mounts and move the engine with the jack or engine lift.
I wish they made cars where you have to take the engine out to change things like that. Cause i will get so many hours at work LOL
its your engine bay stock? i mean if you have cc, battery still upfront, the black canister still in original places. i have none of that and i just removed the intake manifold bracket and disconnect the heater core lines and it comes out real easy. you may have to remove more things but its do able.
I just pulled mine out to the passenger side. There is a big hole over there for me. No manifold bracket, no egr, no canister, no battery try. Took me about 20 minutes or so to get those bolts out. I left the bracket and tensioner stuff on until the engine came out since the pump is 99% of the weight.
