ABS unit leaking
spaceball
79
Jan 19, 2004
wakefield, Massachusetts
my brakes are acting fuct up. a look under the hood revealed that fluid sqirts down from the top aluminun block thing(technical term) when the pedal is pressed. fluiid is puddled up on the top of the lower aluminum block thing. does anyone know how to fix it? i allready tried searching for about an hour and came up with nothing. i dont wan to replace it cause it looks like it cost big bucks.
I had the same thing happen to my car the day after I bought it. Check and see if you can find one on Ebay or the trader. They'll sell really cheap on there most of the time because people don't want them. Other then that, you could remove the ABS from your car if you wanted.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
