abs harness shreaded, advice?
Funfettie
419
3
Sep 19, 2011
Menomonie, Wisconsin
Long story short, I bottomed out my wheels hard, and I ripped out the fender liner and the tire bit into the abs harness shreaded it. I don't have abs in the car, just used an abs harness to replace the last one that was a mess. can I just cut the whole thing off? Anyone know what wires I should cover? (12v constant, switched power, ect. Assuming the abs ecu needed power). Thanks!
Tanner! Just recognized your thread haha. This is Adam, friend of Ben. Anyway, yea I just removed all my ABS stuff and if you want the harness done cleanly and all done up I could help you with that sometime.
Damn whatd you do? Can't just say long story short, that don't apply and it ain't gonna fly, wanna know why, why you grave diggered your ride, evidently so sky high
I don't have abs but I do know, that just barely above the fender liner is the harness that runs ALL your front end lighting, generator relay, oil pressure gauge, oil dummy light, power steering switch, generator wires (minus alt output) regular horn, and a few more odds. I recently rewired everything up front.
Are you sure that's just abs?
Yea it's the part of the harness that's under the passanger fender. Only 1 giant plug for the abs ecu on that end. Took a corner wayyy too fast, and hit a giant crack/pothole. Slammed the wheel into the fender/strut tower and made a mess of the harness.
