Ludachris
Founder & Zookeeper
- 8,880
- 4,727
- Nov 12, 2001
Newcastle,
California
So I got it all back together - changed from a GM MAF to a 2G MAF. Soldered all the wires according to the VFAQ. Put a 1GNT throttle body on and soldered the factory TPS back in place. Didn't touch the ignition system outside of that except to solder a wire that came loose on the Coil-on-Plug.
Turned the key and got the car to start a couple of times but it was missing badly and running horribly rich. I did this before I hooked up the laptop to change the MAF settings. After changing the MAF settings and adjusting the TPS I tried turning the key again... the starter is working like crazy but it just won't start. I figured I flooded it and pulled the plugs and cleaned them up. Put 'em back in and same deal.
I don't know what to look for now. I swapped in another MAF to see if that one was just bad. No luck. It's getting fuel so I suppose it must be spark. Not sure what I should check next. Bad coil? Bad power transistor?
I was so looking forward to this weekend too.
