a while I'm in there question
PharmEcis
93
Nov 7, 2004
Silver Spring, Maryland
In the next few weeks I'll be doing a lot of work to my talon. Namely I'll be doing all the timing components, balance shaft removal, new piston rings, new gaskets (head, exhaust, intake, valve cover), full tuneup, etc.
Is there anything else that I should be doing while I've basically got everything apart like that? Any other bearings I should replace? Anything else to check? I don't want to pull the motor out of the car so a rebore w/ new oversize pistons is a no go unless I find out that the cylinder walls are particularly bad.
I purchased a cometic metal high pressure head gasket. How important is it to get the head resurfaced?
btw.. the car has 148k miles. Was stock until I got it. Seems to have been decently maintained.
Thx for teh replies.
i think its pretty important that you resurface the head (unless you like swapping headgaskets every time)
yes resurface the head so it sits proper on the new gasket that way you eliminate any chance of it leaking afterwoods
anything else I wanna do as far as things I should buy and replace?
I'm lucky enough to be within driving distance of Jacksons Auto Machine and Extreme. Should I take the head to them or will any machine shop do? I'm sure the cost will be higher at JAM or Extreme and turn around time will most likely be longer.
well I was thinking more along the lines of "should do" maintenance stuff.
I'm planning on getting a 6 bolt and building that up and dropping it in later on. I figure the stock bottom end should get me to 300whp or so, I just want to make sure I do the right maintenance things while I have it open and easy access to it.
you've pretty much covered it. I wouldn't replace the bearings unless they're showing abnormal wear signs, and if you do replace them, it'd be better to have the machine shop re-blueprint and balance the engine.
Clean off the pistons and make them nice and shiney again. just inspect and clean anything that shows abnormal gunkyness. Check your valve seals, make sure they're not leaking oil. Just good stuff like that.
V8HAHA said:
remove the balance shafts?
umm reading comprehension ownz you? I already listed that :thumb:
That's what I was wanting to hear. I wouldn't have minded doing something else if it was imperative, but I've already got a lot on my plate now.. hehe
What about the oil pump? The car has 150k on it and I have no idea if this has ever been replaced. Should I replace that just for shits and giggles?
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
