hypergenesis
- 887
- 1
- Oct 21, 2010
Tracy,
California
So this is continuing from my previous thread in regards to an engine I had sent to be built at a local shop.
Read if you like
http://www.dsmtuners.com/forums/hangout/452135-get-lube-ready-quote.html
regardless this is the point of the thread
Warranty
*Customer provided used engine parts:Engine Block,Bare Cylinder Head,Cylinder head internals,Crankshaft,Oil Pump, Connecting
Rods,Pistons,Camsafts,Oil Pan
No warranty provided on used parts
*Custom Work requested by customer:Balance Shaft Delete,Oil Galley Porting
No warranty provided on "Custom" Labor or Parts.
*Custom Work Requested by customer has rendered Cylinder Head "custom" and is not covered by warranty
Custom oil galley porting
*6 month/60,000 miles Warranty provided on Short Block Assembly.
If engine failure Occurs due to Improper Engine installation,Timming Componet Improper Assembly or Customer Installed aftermarket
part and/or Tune.Warranty is Void
also keep in mind half the head was replaced with new parts, valves, valve guides, valve stem seals, springs, retainers. Only thing used is the cams and rockers and the head itself. Yet again bad communication on the shops part since I have asked for a list of everything I brought to them for the past 5 months. ( I have it of course but they don't)
My understanding of this is that its a loop hole that ends up with nothing being covered. Along with this , its for a 6 bolt in a 2g so a tune is going to be a requirement to some degree especially for 2g pistons on 1g rods.
This was their revised warranty after going in to talk to them 3 times.
Also sorry since this is the second thread in regards to this in the past few weeks its just im at a loss between fixing it between the shop or going to the BAR, I figure someone here might have some better insight towards the matter.
Along with this if they installed the BSE incorrectly or ported the oil galley for BogusSVO's Oil Port mod #1 too much then they are covered and im out of luck correct?
Thanks as always to a great community
Armin
(PS help me I just want to have my car running its been sitting for a year, im stuck driving a 3 cylinder geo metro I built...imagine the slowness..
Read if you like
Warranty
Armin
that turned into one of these
