a turbo question a a basic one
Turbotsiawd
130
Nov 7, 2011
Aliquippa, Pennsylvania
I was trying to put the water lines on my 14b and i was just curious as to were the "u" shaped one goes on because we could not figure out how to get it on for the life of me. could some one show me a pic of were it goes on there car please.
And is the hood prop up the same for 1g and 2g?
That line runs to the water pipe and wraps under the CHRA on your 14b.
There should be a bung on the pipe.
If not you need to get the correct pipe the runs from the pump and around the block to the heater core.. or you can run the 14b dry as long as you let it idle down.
I've done both with success.
