A/T trany 13g to 14b swap and cams from 92 tsi 5 speed swap
talon1987
237
7
May 3, 2004
chicago, Illinois
i have a stock 31 tsi A/T ......what would i need to for the swaps i have the turbo and cams do i need any other components .... how much more power would come from these swaps .... and would i have to upgrade my trany for the extra power of the swap
you will need a new Coolant return line(part number MD117764) and Banjo bolt(part number MF650114) for a 14b swap. All the other stock lines from your 13g will bolt up the the 14b.
Also look for a set of used 450cc injectors to go with the 14b's increased airflow. The stock 390cc injectors you have now will be working overtime to supply enough fuel for the 14b. Used 450's can be had for around $50 to $75 for a set either here or on Ebay.
Lastly, if you can find a used turbo 5 speed ECU it will also help out with tuning the car later. Because it has programming for the 450 injectors rather than the 390's in the auto car.
how about the cams ..when i put the cams in would i have to get a new set of cam gears .... and for the 5 Speed ecu would i have to program it or is it ready to go
Your stock cam gears will work fine on the 5 speed cams. The 5 speed ECU will run your car just fine also.
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
