Tranny swap From n/t to turbo tranny.
Gs Dewd
1,270
7
Oct 29, 2003
Crimora, Virginia
Hey wondering if anyone has done this and what wires need to be changed out and so forth. From what I can gather there is 1 extra wire running to the sol. valve with the n/t harness that isn't needed with the turbo trans and I need to add a wire for the temp sensor. Would anyone have a diagram somewhere that will show me where to add the wire to my tcu harness? THe tranny is from a 92' laser and my car is a 94'. From my diagrams the 94' wether turbo or not doesn't have the third wire for the temp sensor but this 92' tranny diagram has it. And also will the n/t tcu run the trans. I check several sites for tcu's and they seem to list the same tcu for n/t and turbo fwd trans. Just wondering if the 94' tcu will run the 92' trans.
I dont even think it will bolt up. Its a completley different trans. Why not just get the correct one?
The car has a 91' 6 bolt turbo engine in it. So it would technically be the right tranny. The n/t tranny was the wrong tranny. But it served the car well and still is good to go but with the added hp it won't be long before it scatters itself. And it does bolt up just had to change the tranny mount the bolts to the frame.
