tranny swap question
byebyev8
344
Jun 17, 2004
kenosha, Wisconsin
I was woundering if I would be able to put a 90-92 auto tranny in a 93 and could I use a 94.
Yea, I finally got my '93 tranny mated to a '90 motor, all I needed was a different flexplate. $15 shipped from a guy ($36 from the dealer), and $20 for bolts.
If it's late enough '92 to be a 7-bolt, then you're good to go as it.
thanks for the info I'll be getting a awd tranny as soon as this one goes out
Sorry to bring this back but all I'll need to do the swap is the flex plate I don't have to get a fly wheel or anyhting
On the autos there is not flywheel. the starter turns the convertor and the flexplate is just the peice that joins the convertor to crank
I wanted to know if I could use a flex plate for a 5sp or does it have to be from an auto and are the driveshafts interchangeable on all models
5sp doesn't have flex plate...thats an auto thing
I ran into a problem similiat too this, I have a 93 Talon ES which had the F4A22-1 tranny and I bought one offline and it was a F4A22-2 and the only difference is the big plugin on top of the tranny. and trust me u can't wire the wires up either I have tried and tried with no prevail, ALl ya would need is a diagram of the wiring on both tranny's "which I can't find" if u please let me know.
thanks
My cars at the shop to get the tranny replaced and now they say taht it don't fit. My car has a fwd tranny for some dumb reason and its a awd car. So I got a tranny and the parts to do the swap shoulldn't it fit I got a flex plate for a 90-92 from chrysler it didn't look like it was the righ t one because I was told taht the 7 bolts have 4 thing and the 6 has 3 and the one they gav me had 4 but now the shop says it won't fit
I have no ####ing clue what you just said
Sorry about that
OK here's the problem I just ended up gettin the wrong flex plate from chrysler I think
I think the 6 bolt flex plate has 3 prongs and the 7 bolt has 4 and I ended up gettin one with 4 and the tranny didn't bolt up
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
