A/T tranny only has two gears
Any luck? I can possibly walk you through a couple of tests. First thing is to check all connectors, wiring and fuses. Do pull the TCU and check for board damage. The TCU's used the same shitty caps that the early ECU's did. They're real bad about eating the speed sensor traces and on rare occasions, short out and burn all the way through the board.
So it's fixed now..Wait the bs belt broke, causing it to feel like only 2 gears..Can someone explain this scenario to me?How did the bs breaking cause the cam timing to be off?
the bs belt is located behind the timing belt when i breaks it can snag the timing belt causing it to break, jump of, or skip a few teeth. With the car running like crap and out of time it will throw everything else off. A lack in power can make it seem like the transmission has got a problem. Any questions?
