a few 1g in a 2g problems
stckmojop
May 25, 2004
des moines, Iowa
well i swapped my 1g motor into a 95 tsi body with little or no problems. Right now i'm hung up on two things.
#1. I'm using a 14b and i can't seem to find a way to connect my lower IC piping to the turbo, i have the 1g and 2g hoses and the elbow that connects to the 14b but neither hose will reach. Anny suggestions?
#2. THe counterweight on shifter is getting in the way of my lower radiator hose. Is there any way to remove it or get around it so they don't rub on each other?
thanks in advance! :talon:
well i'm not sure as for the I/C pipes but the counter weight on the transmission has to be cut off, you can probably use a dremel drill or a grinder, good luck with the 1Gina2G. mine has been nothing but problems but thats a DSM for ya, good luck :dsm:
Well, you could try as a temporary fix...cut the hose in half, grab a pipe of a certain size, just long enough, so the end can reach, clamp that bad boy on and ride. :cool:
