A/F, BOOST, VOLTS gauges help!!!!
snowboarda10hal
32
Oct 8, 2006
west newfield, Maine
I was wondering if anyone knows where i can find some pictures of how to install these gauges? And if no pics, a good detailed overview.
a/f signal wire goes to i believe the gray wire of the four on the o2 sensor. you should have two blacks, a white, and a gray if i remember correctly, something similar to that. the boost source should either tee from the fuel pressure regulator vac source, or port p on top of you throttle body. it's the one with the red striped line coming off the tb. as for volts, hook up to a +12v source and you'll be fine.
Awesome, thank's alot. Just one question.. When you hook up the A/F to the 02 sensor, what do you do cut the wire on the o2?
Don't know about the A/F gauge (why did you buy one anyways?). For volts, I tapped in the cig lighter. For boost - T off the fuel pressure selonoid. Check the tech guide (they are a few threads about gauges) or do a search on here.
No. All you need to do is splice into that wire. DO NOT disconnect it or you'll have problems, as in your o2 sensor won't show a signal to the ecu because the signal wire has been cut.
