CyberEye
- 947
- 4
- Jun 25, 2002
Gas gauge isn't working, driver side power door lock stopped working, sunroof not working.
The gas gauge all of a sudden stopped working, it will only move between a little above half a tank, to a little below half a tank. I checked the float when I changed the fuel pump, it was moving fine, and read from 12 to 38 ohms, stop to stop on the float.
Last night, the driver side power door lock stopped working. It wont lock or unlock with the remote, or with the power lock button inside the car. It will however still work manually. Since my key doesn't work very well in the door (very stiff, just twists the key) It's a fairly big problem.
Last but not least, the sunroof. It feels very weak when I try to open it. Sometimes it opens, sometimes it ony opens slightly then stops when it's raising up. It almost always has trouble closing once it decides to stop opening, but if I push up on the glass a few times, it usually manages to close itself afterwards.
Suggestions on any of these problems would be greatly appreciated.
Thanks
Thanks
