99 GSX no tach after sitting
skyrone
230
Jul 12, 2007
Gillette, Wyoming
So after sitting for 3 years i finally got my eclipse running again. It is running decent but I am still tracking down some air leaks. Right now I have no tach or oil pressure, tested oil pressure with a gauge and its good. I have rpm readings on my dsmlink but the gauge doesn't move. I searched around a bit and didnt find anything specifically relatable. I was going to start with replacing the ignition transistor. However I was thinking if my oil pressure gauge and tach are acting up maybe something is fried in the cluster. Any thoughts?
Odds are it's something with the cluster. My speedo stopped working once, I just tapped on the cluster and it started working again.
In your case, I would at least pull out the cluster, maybe check out the connection in the back where it pushes into the plug, the terminals could be corroded.
