98 Spyder GST
TurboPirate
Aug 25, 2012
Hormigueros, Puerto Rico
Hello gang, haven't post a question since 2012 but now I got a 97 Spyder GST the convertible part I don't like but wondering if there is an aftermarked one piece fiberglass roof I can replace the soft convertible thing........I got the car with running problems it once detected a bit of Boost ECU didn't let it pass 3,500 RPM, checked under the hood found a air compressor regulator installed wrong, took it all off connected vacuum lines to factory places and now it runs smooth, but that is another story, the roof thingy is my number one concerned....thanks in advance TP
Thanks for the answer, got another question, is it possible to lower the Boost? It runs at 10 psi ecu makes sure it doesn't pass 10 psi, until I get the repair kit is there a way to nakk it runs just at 5 psi boost not more?,
