bottlefedb16
- 0
- Dec 30, 2004
reistertown,
Maryland
The car is a 98' GS-X DSM. Only mod.'s are upgraded greddy intercooler piping , Greddy BOV ran back into the instake like stock , intake , and a 3" thermal exhaust with a 2 1/2" down pipe and a high flow cat. The car boost fine and holds pressure but the car feels like it had no power and keeps fouling plugs I pulled the plugs and the base of the plug is black and the tips are white and you can smell fuel on them like it's running too rich. Here's a list of the things I've checked or replaced :
- 02 sensor has been replaced /
-I've tried swaping MAF sensor with another car, no difference
-Changed plugs and wire.
-Checked the resitance to each terminal for the coil packs and they're are with in normal range. and nothing is arching.
-took Cat. converter off to make sure it wasn't clogged and it's fine.
-Timing belt HAS NOT Jumped marks are on.
-Swaped out cam angle sensor,no difference.
-Swaped out fuel pressure regulator,no difference
-check all injectors resitance with a volt meter injectors are fine.
-Fuel filter was changed recently.
-Like I said car boost and holds fine so I can't find any boost leaks.
I'm open to any suggestions. I didn't just go out and buy parts I have alot of turbo DSM parts sitting around my shop so thats why I was able to just swap parts out.
