97 talon tsi awd clutch problem
tsiboost14
36
Oct 24, 2012
Newport, Pennsylvania
Hey my name is joe and i own a 97 talon tsi awd and i have a question i need help answering. i was setting my boost the other day and my clutch was working fine when i parked it a few days ago but i went out this morning to start my car and when i just barely touched my clutch pedal it flew to the floor like it was spring loaded and stayed on the floor. in order to get the pedal back up all i have to do is pull on it a little and it flys back up. i checked my clutch fluid and it was empty so i obviously have a leak somewhere but im not sure where. the slave did not look damp at all. i tried bleeding the clutch but it did not work because it seems like its not even engaging. any ideas on what it could be and what i could do to fix it? it is not a stock clutch either its a stage 3 slowboy racing clutch with a lightened flywheel.
Master Cylinder leak? My little brothers GST had that problem and he replaced the MC and its firm as ever.
Try putting fluid in the MC and pumping it to see if the hydrologic lines that are leaking.
thanks man ill deffinatly check it out and keep it updated really appretiate it
the MS seems to be fine but i know there is a leak somewhere but it has to be small because it takes a few days to a few weeks to drain out completely. i moved the car and didnt see any leakage on the ground or anything.
my master and slave cylinders were leaking all fixed now thought thanks for the advice bud i really appretiate it!
