97 gst...:(
deviousgst
931
Mar 24, 2008
bakersfield, California
so on friday some truck hit me and took off....so now i need a new fender (passenger)..
i was wondering if a fender off a 95 eclipse gs wold fit on my 97 gst...
thanks in advance.
They will fit. I'm running a 96 talon fender on my 97 GST and it fits great. Also, if you can swap 97 front bumper and headlights onto a 95, you should be able to run a 95 fender.
It should fit fine because the main difference with the 2ga and the 2gb are the gaps that you see when someone tries to install 2ga headlights with a 2gb bumper cover.
Yes It should seeing it's between 95-99 when the majority of the structures are the same, your local junkyard should have it for like 40$ just a fews bolts and you're good.
