97 eclipse gst P0505 Problem
Trison
51
Aug 30, 2011
Sierra Vista, Arizona
I have a 1997 Mitsubishi Eclipse GS-T. I don't have a Check Engine light but i did use a engine code reader and i got P0505 Idle air control system. Once i start the car it idles high then low and just jumps around then it finally dies. Unless i give it gas and continue it for about 30 seconds then it levels out and stays on. I cant figure out the problem or what to do exactly since I'm still learning my car. Thank you.
Still cant figure out whats going on with this car.
I checked the idle air control motor and cleaned it all out and put new gaskets and its not leaking at all. Just figuring out which problem is the pain in the arse part.
