96 gsx fuel pump wiring hard wired to battery
_4g63_
35
4
Aug 12, 2016
Sparks, Nevada
Hey i was wondering why someone would wire a 12v wire straight off the battery to the fuel pump. I recently bought a modified 96 gsx with a 6 bolt motor. After pulling out the harness for replacement i found two other wire running along the harness through the firewall. One was a electronic boost controller cut right after the firewall and the other was a 4 gauge wire running from the + battery terminal to the fuel pump, with 20a inline fuse.
Sounds like you are describing a standard fuel pump rewire. Very common and is a must with a modified dsm requiring more fuel. The rewire ensures the fuel pump is getting enough Juice/voltage that the stock small gauge wiring doesn't provide.
I could only find a 20 amp fuse inline about 8 inches from the battery. Ill look more today after work. Thank you for the replys
Considering I can see the separate ground coming from under the fuel pump access panel, I can almost guarantee the relay is under there as well. As previously said, very common mod, and a must for modified cars.
a lot of people put the relay under the fuel pump access panel. between the fuel tank and floor pan of the car basically. i do not recommend that location but one of the 'how to' documents on line does that and everyone follows it.
Where would you recommend?
It is under there
